bhollehday
- Aug 16, 2017
- 77
Ive got a 2006 Larson Senza 206 that I use for towing and cruising. The recommended WOT ROM range is 4600-5000. I have a 14.5x17 4 blade aluminum that WOT RPM is at 4500 and about 40mph. My 15x16 4 blade aluminum was WOT at 5100 RPM (I had to pull off a smidge to keep it at 5000). I need to buy another prop and want to jump out of the water with the most top speed. The 16 felt a lot more jump and pull and I didnt get more than 1-2mph on top speed with the 17. Could I go with a slightly larger diameter 16p to bring the RPM down?
