dhendr11
- Apr 28, 2018
- 10
Hey everyone, decided to try out the boat life and purchased a "trial" boat just for family fun. However, I got too close to a sandbar at the lake and well that prop needs replacing. Luckily no damage to engine or outdrive but I wanted to get opinions on a replacement prop. Looking to replace with a stainless steel but do I need to change anything pitch/diameter wise before I just buy the same specs below? The speedometer isn't functional at moment so not sure about speed at WOT.
1991 Glasstream 180 SE (17.5 inch Runabout, 2425 lbs empty)
1991 Mercruiser 3.0L I4 with Alpha One Gen 2 drive (1.98 ratio)
Michelin Match Aluminum 14.5 x 19
4500 rpm @ WOT
4500 rpm @ WOT
