Jasonfishing
- Mar 2, 2018
- 6
Hi, new member looking for any suggestions and thank you in advance for the help. I have a 2000 Hydra sports center console with a 2000 90 horsepower 2-stroke Johnson. Currently I have an aluminum prop, it's the original that came with the boat 14 x 17 OEM prop. The prop works great, but it's a little dinged up and I have a friend who has a prop for sale for $80, brand new in the box stainless steel Michigan wheel 15 X 17. Model 013044, it was their spare for a boat they no longer have, least to say the $450 prop for next to nothing so if it'll work on my boat I'll get it. My wide open throttle on normal load is about 5100 RPM at about 41 miles per hour with the aluminum prop any suggestions? Will this prop work with same performance? Not looking to dump three or four hundred dollars on a stainless, thanks for any suggestions
