Tohatsu TLDI 115 on a 22' dory. WOT range:52-5800. I have a 3 lobe Solas New Saturn prop 15 pitch. At WOT I'm right at 5800 rpm without hitting the over rev limiter. Sounds perfect except that I'm also going 40 mph. Rare is the day when I could use that speed in the Gulf of Alaska. I'm thinking about a Solas Titan 4 lobe to improve mid range performance. 1. Does that make sense? 2. If it does make sense, should I keep the 15 pitch? Bottom line...I wouldn't mind trading 5 mph top end for a better life in the middle. Thanks for any suggestions!
