waterdog55
- Dec 3, 2017
- 3
1986 Boston Whaler 18' center console
2005 Mercury Optimax 150, 1.87 gear ratio, mounted two holes up (third hole)
WOT range is 5250-5750
Currently operating a Stiletto Advantage SS prop, 4.75 series, 14 1/4 x 17 pitch (E800317)
The following was taken on salt water, 3' swell @ 15 seconds, 5-10 knots wind, ran the tests in the ditch. All speeds taken from GPS.
Current performance:
time to plane, 5 seconds
2500 RPM, 11.5 knots, full trim, not on plane
3000 RPM, 21.8 knots, +2 up from full trim
3500 RPM, 27.4 knots, +2
4000 RPM, 30.4 knots, +1.5
4500 RPM, 33.8 knots, +1.5
5000 RPM, 37.3 knots, 1
WOT 5200 RPM, 39.1 knots, +1.5
primary concern, would prefer to get the WOT up near the top end of the range.
secondary, would like to improve hole shot, lower the minimum planning speed and better performance in rough seas.
It was suggested by a well known prop shop that I try a 15 pitch 4 blade prop. They suggest I would get all I was looking for and increase the RPM by about 400 RPM's. My understanding of 4 blade props is that the performance would increase because you have more blade in the water, ie more torque but not gain any RPM's? I know if I simply go to a 15 pitch the RPM's would go up but may not get the performance on the lower end? Also suggested to me that I stick with Mercury props, not sure why, they sell many brands.
I would like to hear prop suggestions, manufacturer, pitch, number of blades. Any other feedback?
