23 Cleaver 4500rpm
21 unknown 4750 rpm
Cleaver props are stern lifters and are great props for competition tunnel hulls where the risk of the boat catching too much air will flip it over. But are not the best choice for bass boats
Chopper Props were popular on bass boats in the 70s and early 80s, these were bow lifters. They had the ultimate venting, Over hub exhaust.
You have to prop it for WOT. Over propping and trying to unload the blades by using the vent holes to get respectable HoleShot will still result in too low WOT RPM. The Merc V6 is not lacking in low speed torque, when propped for 5500 rpm.
Your numbers so far will indicate an rpm of approx. 5200 - 5300 if you get a 19". Engine setup, as in height, will have some effect on acceleration and rpm
A Laser II is often used on fishing boats, but it has very large vent holes and running it without any restrictor plugs may result in serious blowout on acceleration.
My personal preference for a prop is Mercury's Enteria. It has shown to be a very good prop in a variety of applications. But like with any prop YMMV
