Have a 1988 Merc 175 Blackmax. My son and I just put on new flo torq hub and put her in water. Idled out a ways and then slowly throttled up. Ran like a dream for about 45 seconds and then prop started spinning. Idled back to marina, pulled boat out and checked prop. Apparently my son (cause I never would have..ha) didn't tighten nut anywhere near 55 lbs. the nut was very loose, after slight pull was loose. Unfortunately we have now a stripped shaft and can't get nut off. So I have two questions...would a less than fully tightened nut cause the prop to spin under load. The castle was still in the slots. Secondly, how big of an issue do I have with that stripped nut? Thanks
