1978 Evinrude 9.9 HP has been setting for 15 years. Took it to a dealer to be checked out before use, they changed the lower unit oil and gave it an "A-OK". Went to use the boat at Lake Taneycomo (a cold water lake below Table Rock dam) and all went well for about the first 20 minutes after that the engine would over rev and the speed of the boat would decrease. Seemed like a classic spun hub, was able to return to dock at low speed. Got home & pulled the prop, no visible damage. Marked the hub and prop to verify spun hub. Went to a local river and tried for an hour to get a repeat performance to what happened at the lake. I was not able to get the hub to spin in an hour of trying with repeated hole shots, etc. My question is can cold water cause the hub to spin but in normal temperature water the hub would work as it should. That doesn't make sense to me. Does anyone have any ideas as to what else I should be looking at? Hate to go out in a boat that I'm not sure of. Thanks.
