It's a 4.50 Mt Rib with a Tohatsu 2 strokes 18 HP, with stock prop 3 X 9.2 X 9 pitch achieves 50 rpm less that its factory wot range which is 5800 rpm, that's barebone loaded with just driver around 400 Kg. Changed to a 3 X 9.2 X 8 pitch and engine over revs to 6250 rpm which is + 500 than "rule of thumb", ideal would have been an 3 X 9.2 X 8.5 to decrease just 200-250 wot revs, but impossible to get, that why was asking, the only available is the 3 X 8.9 X 8.5 pitch
Have 2 options (1) go for a 3 X 8.9 X 8.5 (2) have factory delivered 3 X 9.2 X 9.0 pitch re pitched to 3 X 9.2 X 8.5 pitch. The issue is that don't know if first option will fit my current engine's prop shaft as it's from another HP model engine. We're talking about standard cupped alum Tohatsu props.
Will you need any other info to evaluate the combo, I'm just doing a prop maximization to be where I want to be. That's half of the total over revving, know that as soon more load is added rpm will drop accordingly. Thanks,
Happy Boating
