100333624
- Apr 24, 2012
- 205
Hello this is kind of a mixed topic I guess, I am looking for your advice for those who are familiar. I have been in the process of propping my rig properly. I am currently running a Laser 2 in 20" pitch and was recently getting only 5000-5100 rpm with all my tests on that prop. After careful observation of the anti vent plate I decided to raise the motor, so I recently raised it one hole up. When leveled out the boat bottom to the anti vent plate, it currently is sitting 3/4" above the bottom of the transom and I still have one more hole that I can raise it. After doing 2 test runs with the new height, the first got me about 5300 rpm, BUT the second test today got me to 5500-5550 rpm trimmed out?? The thing is I had 2 completely different trim results today from last week. Today it seemed like I could trim so much out and I did... It just kept going and going and I hit 79 kph, the other day it was a touch slower by 1 or 2 kph, but I didn't notice the trim out this much? I usually trim to where the boat starts bouncing, then I trim in just a touch, but today I could trim out so much I was scared maybe I'd pull the prop out a bit and over rev the motor? I did notice the steering was very stiff while trimmed out too, and I have hydraulic steering. The conditions today were a little less windy than last weeks test, and so less choppy, could that be the reason?? It just seems that once you think you start to learn your boat, there comes a curveball somewhere to throw you off...
I thought I was going to have to get rid of my prop because I wasn't getting enough rpm but after todays results I guess its the right prop for me? I noticed since switching motors (used to have a 50hp 4stroke, now have a 115hp 2stroke) my gas mileage has almost doubled or tripled?!? I was used to filling up about $30 every trip with the old motor, and up until 2 weeks ago I over filled my tank (100 liters) and so I had a little extra weight to my first test runs. After about 3 or 4 fishing trips out I still have over half a tank left?!?!? I will admit I don't drive around a lot but when I do I'm going full speed for quite a few kilometers. To add to this, after todays test run while looking back at the motor as I was trimming out slowly (I trim out a little bit at a time) I noticed some different splashing going on which caught my attention, I can only think it was the anti vent plate or most likely the other plate above it throwing off water at a high angle behind the motor in a V shape (NOT a rooster tail) one line to the left one to the right. When I did another run to check it out, I told my partner to hold the wheel while I went back to see and it wasn't doing it now, so it could have possibly been weeds maybe? Very strange as its never happened to me before. But I noticed my anti vent plate was still buried in the water so I think I have to come up one more hole which will be the maximum height I can raise it, and the plate will be 1.5" above the bottom of the boat. Now I gained like 400 rpm from raising it one hole, whats raising it another hole going to do?? Will I have to go up in pitch to a 21? This stuff is so weird and strange, I was certain I had to go down in pitch to increase rpms before thinking about raising the motor, but seems like it's going the other way around?? I am afraid if I go up in pitch the holeshot isn't gonna be that great, its already border line OK, or do I just keep this 20 pitch and add some more cup to it to bring the rpm down a bit and better bite?
PLEASE give me your advice, I am eager to hear from you who have been in this situation.
Thanks!
Nick
Thanks!
Nick
