StingRay_90V4
- Aug 26, 2014
- 155
I have a 92 16ft Stingray v-plane hull with a 90 hp evinrude. The origianl prop was a Omc 13.25dx17p omc prop. The boat had decent hole shot and a top speed of 38-40mph at 5600 to 5800rpm. Depending on load and the weather. On a few calm mornings i have hit 41mph at 5900rpm. Im looking forna new prop as our old omc has hit a sand bar/ rock. Broke one of blades and bent the blade right in half. I am lppking for a new prop. I have an OLD solas prop that is a 13.25dx17p as well. Or at least i think its a solas. Its deffinitly not an omc i dont think. The prop has larger blades. But is the same pitch and diameter. Our boat seems to have gained some bottom end for sure. But lost about 1mph or so at top end. Now getting about 38ish mph top speed. I am wondering what well be any advantages between an omc prop and or solas of the same spec for whole shot and top speed between the two. And ir any other prop i should buy for an extra mph or two. Its all abiut the top end for myself. Lol... Although my motor is still sitting on the bottom gole on the transom and the ac plate ia about an inch BELOW the boat. I NEED TO raise my motor one hole and im sure i will gain at least 1 to 2 mph there also. Im looking for 41 to r2mph. Any advice and or thoughts?
