I use my boat on a lake that is about 9000 feet above sea level. That impacts performance significantly. If I get more than 4 adults in the boat, or a full tank of gas, I cannot get the boat to plane on the water. The RPMs go up to about 2100 and no further. The boat: 19' Bayliner, open bow. One potential solution is to change props. I am already using a 15 pitch cupped prop on the 125 HP outboard Force engine (1985). As near as I can tell, no one makes a 13 pitch prop (probably due to low market demand or something).
Anyway, does anyone know if there is a company that makes custom aluminum props (12.5" diameter, 15 tooth, exhaust isn't through the prop, probably don't want the prop cupped)?
