goblerblaster
- Dec 26, 2011
- 176
I have been working on a 9.9 Nissan 2 stroke 1997 model that was having carb issues. I got it running good in the water barrel, so I took it to the lake on an aluminum 14x35 flat bottom boat. The motor will start right up and not miss but it will not plane off the boat. I thought it must still be a carb issue. Break down the carb again, got it running good in the barrel, back to the lake and it doesn't miss but will not plane off the boat.
I got to noticing that it almost felt like the prop was slipping - especially when motor was in reverse. I have looked at the prop and cannot see any signs that it has "spun a hub", but don't really know what I am looking for. I can put the motor in gear and turn the prop and it turns the motor over without slipping. I put a wooden block between the prop and cavitation plate and can't get the hub to spin without the blades in sync.
How do I test for prop slippage or any other ideas that might help.....
