dbblackburn
- May 24, 2009
- 24
i have a 86 hoosier crank up or scissor type trailer 2 axel whats the proper way to use this type how high can you travel with it? any other safe operating tips would be grately appreiciated.
mine is about 26 fy long before the tonge and in great shape i would gladly trade it for a bunk type but i dont think that would happen maybe next year i will sell it and invest in a bunk type. there is no lock that i see but a safty cable but it is too long and lets the boat ride too low in danger of scraping the tubes in the back might have to adj the cable to let it goe up more
The cable with the 'S' hook on it hooks onto the trailer up by the crank. When the trailer is all the way up the cable will be loose when hooked onto its spot but as you lower the trailer the cable will tighten up. When both the crank cable and the safety cable are tight you are ready for the road. The trailer won't lower all the way with the lower cable hooked on. You have to crank the trailer up to loosen the lower cable and unhook it then it will lower all the way down as long as the lower cable isn't hooked onto anything. Hope this helps.
