Welcome Guest - Sign Up today
Announcement
Collapse
No announcement yet.
How to Safely Jack Up Pontoon on Blocks
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • How to Safely Jack Up Pontoon on Blocks
    I store my pontoon boat in the yard over the winter. I had the marina pull my boat out of the water and place it on blocks in the yard. I wasn't there when it was delivered and although the block are all even with one another, the land is sloped leaving the port side of the boat a good 3-5" lower than the starboard side.
    I was wondering if there was a safe way for me to jack up the port side pontoon to slide in more blocks to level it out.
  • #2
    Having it slightly off level like that is going to help it drain quickly. I can't think of an advantage to leveling it.
    If you insist on lifting it, I would spread the weight of each corner across 2 cross members then lift. I've done that a couple of times, shade tree style, with a floor jack and a couple of 2x4's.
    Comment
    • #3
      Seems more than slightly off level to me, but if it doesn't hurt to have one pontoon supporting more weight than the other I guess I'll just leave it.
      Comment
      • #4
        Keep in mind you dont need to jack the tires off the ground.... I'd start with the low side, blocks and shim it till u get about 1/2 the weight off the wheels, then other side.... that's what I'm doing... my storage sight is nearly level tho
        "Na ise kalyteros anthropos apo ton patera sou"
        (greek= Be a better man than your father)....
        Comment
        • #5
          Sign up today
          Guys - The tires left with the marina delivery trailer. Reading comprehension is a lost art.
          I wouldn't worry about the toon sitting level unless one of the blocks is lower causing a possible twist.
          BOAT SPECS | FORUM HELP | STARCRAFT FORUM | SHOP iBoats
          Please, no PM's (Private Messages) regarding boat/engine problems.
          That is what the forums are for.
          Only forum/moderator issues will be answered in PM's.
          Comment
          Working...
          X
