Welcome Guest - Sign Up today
No announcement yet.
whats the best patch kit for pvc boats and checking for a leak method?
  • whats the best patch kit for pvc boats and checking for a leak method?
    I lost my repair kit that came with my boat so I gotta buy one. What's the best way to check for leaks and where they are coming from? I figure pump it up leave it for about 8 hours then if it loses air repump and go around with a spray bottle looking for the hole?
    Re: whats the best patch kit for pvc boats and checking for a leak method?
    Yep, pretty much. If it is quiet and your hearing is good, runnig your hand over the surface very lightly will create a hissing noise where the air is escaping. That's how I found the prick (oun intended) in my floor. Drier and faster, if it works for you.
    Saturn 365/ Johnson 15 hp
    • #3
      Which kit should I buy?
      • #4
        The standar patching kit is not vey good as comes along a one part glue, get the one that comes with a 2 part glue, that's glue + hardener, if available, much more efective and long lasting patching.
        Happy Boating
        Sea Rider 320, 380 Sibs, 450 Rib, 2 Strokes Tohatsu 5,18 & 30 HP Proud Smokers
        • #5
          Happy Boating
          thanks for the info, can you recommend a good glue brand to buy (maybe give us a link to one)?
          • #6
            I fix a pea size hole in my boat with standar patching kit about 2 years now still going good ....
            here is nice video for you How to repair punctures in PVC inflatable boat, raft or kayak. - YouTube you should be fine just give it good 24hr to set in low humidity ...
            • #7
              Good to see you posting Maakx. I agree with you whole heartedly. That's how I fixed the pin hole (actually fish hook) leaks in my Quicksilver
              • #8
                The only difference between both glues is that 2 part glue will outlast the one part glue in light years. Not good for larger patching work in which you need a better patch/fabric state of the art bond.
                Happy Boating
