Welcome Guest - Sign Up today
  • Dear Community Members,
    Over the last two years, there have been updates to the environment that have introduced challenges in usability, performance, and security. Efforts to improve the technology, user interface and site performance have revealed weaknesses in the platform and outdated software our site uses. This has made it increasingly difficult and frustrating to support and upgrade to more modern reliable standards that users deserve. This is not the experience we want for the members of this community.
    Members want a fast site that performs well across all devices, to be able to find relevant and interesting content, and easily share through text, images, video, and messaging on a secure platform. Our goal is to provide this user experience to all members. We will be updating to a new platform to better meet the needs of this community and allow us to provide support more efficiently. Our focus is to create a sustainable platform that performs well and loads faster on all devices while offering seamless ways to search and connect. Technology is constantly innovating - by creating an environment that we control we can maintain the site with more frequent improvements and maintenance updates.
    Although change can be difficult, we are here to support you through the process. We make every effort to review existing settings and make the changes needed so the migration goes smoothly. If you notice something doesn’t seem correct once the site goes live, don’t panic! We’ll have a dedicated person monitoring as the site goes live to answer any questions and provide support through this change. What’s next?
    When will this be happening? The plan is to put our current forums into maintenance mode (off line) at around 9am MST on 9/30/2020! The whole transition should take 24-36 hours. We recognize the user experience is slow and there are bugs from the outdated software. The sooner we can change that the better we can make the experience for you. You’ll start to see activity related to cleanup in preparation for migration very shortly. We will post an announcement to the community prior to starting the actual data migration.
    We appreciate each member’s contribution to this community and look forward to an improved experience for you all.
    - Management
No announcement yet.
Swim/Emergency Ladders
  • Swim/Emergency Ladders
    Hello!
    What do you use as a swim ladder or emergency ladder? I was thinking of just tying a loop in a line and hanging it over the side if someone is in the water ... just enough to get a foothold and pull yourself up in the boat. I'm sure there are lots of other ideas/products out there. What do you use?
    Ever try getting into a boat by crawling / pulling yourself over the gunwale? Next to impossible...
    As a fisherman I didn't want anything permanently attached the transom so I went with a removable "dive" ladder on my last boat.
    It worked, but I boat alone quite a bit and wanted something that I didn't have to deploy between uses.
    I now have a wireless kill switch to shut down the boat. Stand on the lower unit to get back in the boat.
    • #3
      Assume that you are inquiring ladders for Sibs and Ribs uses, right ? If so...
      That's precisely what you need, a rope ladder is the fastest to deploy at any moment and the least bulky of all ladders. Can install it up front, middle or aft depending on where are the seat patches located or at both rope sides. It's a matter of standing on loop, lock the knee against side tube and pull yourself in....
      Happy Boating
      Sea Rider 320, 380 Sibs, 450 Rib, 2 Strokes Tohatsu 5,18 & 30 HP Proud Smokers
      • #4
        Thank you. Yes, I am inquiring about a SIB. A picture is attached. I don’t have the same seat patches as you and would likely have the seat installed anyway. What would be the best option for securing the ladder? Can I use the rope threaded around the top?
        • #5
          Better will be to tie a 1/2-3/4 " belt from right tube ear line (1) to the left one with a belt loop on (2) as to distribute much better the boater's stand up weight, pull and climb force exercised to get on board with a foot loop at the end of the belt.
          Click image for larger version
Name:	Belt Ladder.JPG
          As currently installed, both displayed oars and side handles are going to hinder, rub anyone when pulling on board.. If installing a rope ladder will need to remove one of the oars to climb in between the oar holder and the adjacent handle to have a better climbing comfort zone whether at front bow or aft transom area.... If too complicated, try pulling yourself up while standing on the AV plate.....
          Happy Boating
          • #6
            Thank you so much Sea Rider. I really appreciate you expertise and assistance.
            • #7
              You're welcome.
              Have gone myself through same to make my boating experience and others on board more pleasant. Forgot to mention that probably won't need to remove any oar when climbing. Try turning and securing the oar paddle to the other side or swing the oar perpendicular to the tube, check which method gives a better distance clearance to climb on board.
              If you and your boating guests are feather champs skip the loop on 1 or 2 depending which tube will be using, just secure on the opposite tube and try it out....
              Happy Boating
