Re: is 1100 hours on a boat to many
they are asking 7500 for it and by the way the boat itself looks it looks like everything was well maintained on it. We are 350 miles apart so he is going to start by sending me pictures of the outdrive and engine compartment before I go look at it. I could do a compression test on it if they would let me I wonder if they would since it is winterized. I'm also going to ask them if any service records come with it. I thank you guys for the quick replys and I will let you know how it turns out for sure. I've never bought from a dealer before so should I ask them how many other charges there going to stick me with before I make an offer or travel to look at it or hire a boat surveyor to look at it?
I only traveled 325 miles to look at (and eventually purchase) my first powerboat. It was also through a dealer, acting as the broker, so similar to your situation.
Basically, the process typically works as . . .
- You want the boat
- You place an offer along with a 10% deposit, along with your 'contingencies' (i.e., sea trial survey, compression test, etc)
- If/once the seller accepts your offer . . .
- You have all the testing and trialing done (at your expense), but the dealer should 'present' the boat in the water and on land for the trail and surveying at their expense.
- Probably should include proof of ownership (title) as part of your contingencies.
- You decide if you are OK with the boat after your testing, etc is done
- If you are OK with it, you pay the balance of the agreed price, the seller/owner signs over the title.
- Hey you just bought a boat.
I put an offer on the boat in December 2004, did the sea trial and survey in late Feb 2005, bought the boat & picked it up in March 2005. I managed to get the only 'good' day in February for a sea trial, and also paid to have the boat re-winterized. It snowed the next day.
