Re: hour meter
On 99.9% of the gas engined boats, the key left on will run the hour meter.
If you leave the key on, yes the battery will run down, but not from the hour meter. The fact that the ignition is energized along with all the instruments are also on and drawing a lot more amperage than a clock.
The hour meter might run a battery down in a year.
