My 1986 Bayliner Capri with a 125 hp Force stalls whenever i engage it into gear. The only way to keep from stalling is to goose it first. This happens cold or hot. What could be the problem?
On the left side of the engine the is the tower shaft that is connected to both carbs and timing advance. Near the bottom is the idle speed screw that acts as a stopper against the engine block. Screw in raising idle speed enough not to stall! Docking must be a panic.<br /><br />------------------
