In Texas, we are now required to remove the drainplug and drain the bilge water prior to changing lakes. This is part of an effort to stop the transport of zebra mussels from lake to lake (as I understand it). Does the heat in the engine kill the zebra mussel larvae? If not, it seems as though the critters could simply ride along in the engine and hoses till flushed into the next lake.
Has anyone had problems with them taking up residence inside an engine or outdrive? What do you do to combat this?
Apologies if already covered, but I didn't see these particular questions in a search.
