Welcome Guest - Sign Up today
No announcement yet.
Nylon Mounting Slides For Canvas Top On a 1970's Starcraft Aluminum Boat
  • Nylon Mounting Slides For Canvas Top On a 1970's Starcraft Aluminum Boat
    I own a 16' 1970's year Starcraft boat with a canvas top which opens. It snaps into place and opens by sliding on rails which are mounted on the gunnels of the boat.
    I need to replace the nylon pieces which slide on the rails. Each piece is approximately 12 mm wide x 63.5 mm long. I need to replace them because the screw holes are stripped and the screws will not hold tight. Please tell me where I can buy them.
    Re: Nylon Mounting Slides For Canvas Top On a 1970's Starcraft Aluminum Boat
    Welcome to iboats.
    Try here and look around in the "store section" and you might find the piece http://www.iboats.com/Bimini-Top-Sli...view_id.693698
    This is a great link to boat specifications http://boatspecs.iboats.com/
    Please, shop iboats first!!
