acarroll89
- May 9, 2012
- 24
Hi everyone, i'm new to the forum and relatively new to boats. Been reading around trying to find as much information about my boat as possible. If this thread is in the wrong place, can somebody move it to the right spot? But its an 89 tracker 1800fs and it sits in my driveway and collects bugs and water. Its been to the shop to have everything gone through including floor replacement, new seats, rewiring, removed the oil pump thing (we just mix oil in the gas now) and the motor gone through. That was probably 8 years ago.. And its only been used a few times since then. So school is out for summer and I told my Dad i'm gonna take the boat to my uncles where we can put it in his garage, dry it out and start getting it fixed. I also detail cars and several months ago I took it up to work and soaked the whole boat in degreaser and pressure washed everything really good and steam cleaned the carpets. I also acid washed the hull as our sprinklers hit it and we're on well water.
Now last Friday I took it up and let it dry over the weekend and last Monday we started on it. Bought all new batteries for it and have been going through everything to try and find what works. I bought some compound and buffed the hull out (needed it badly) and then pulled all the storage bins to empty those out and clean the oil that leaked in them. So now heres where we're having problems. Trolling motor works, but only as an on off. The pedal has several speeds and an off setting and none of the different speed settings work. The switch to go between 12v and 24v does not work either. It did on Monday, but today we replaced a few relays that were corroded and now it wont switch to 24v. Thinking its possibly the switch panel up front? I pulled the switch panel by the throttle and all of the toggle switches are corroded too, so I hit them with wd-40 and got both of the aerators in my live wells to work. Bilge works, but sounds like its going to burn up, all the lights come on but they're super dim. Of my switches only 2 of them light up and my fuse panel is on its way out. You can tap a wire and cause something to short out. Super tight connection but any kind of vibration screws it up.. As for gauges, volts, trim, and tach are the only ones that work. Dad replaced the speedo a long time ago but he never hooked everything up and now there is a white wire coming out of the back of the gauge and nothing to hook it to. Also the depth finder does not work anymore. We also bought a steering wheel puller to pull the wheel because the hub blocks the dash from coming off. We just bent the bolts in half and the hub didnt budge. I dont have enough room to lay under the dash and look at everything so getting to the wiring for the gauges is extremely difficult. So this is becoming a more and more fun project by the day.
We did get the motor to fire up pretty easy, but its not pumping water. You can feel air come out of the tube, but no water. Gonna take it out to the ramp tomorrow and put the motor all the way in the water and fire it up.
So heres my questions,
Where is a good place to get relatively OEM looking rocker switches to fit the factory panel?
Can I get any modern fuse panel and rewire everything to it using the new style fuses like whats in a car?
What would cause my trolling motor to stop switching between 12 and 24v after it worked with old worn out wires?
With the speedo, would the white wire be a 12v power? Vacuum lines and I believe the grounds are hooked up.
How do you get the steering wheel off of the boat?
Bout all the questions that I can think of for now. I did try searching and i've got a few generic wiring diagrams that i'm going to compare my wiring to. We shall see how it goes tomorrow
Now, heres some pics
Probably a year ago the boat sat with this much water in it for who knows how long
Leaving my house
Starting the buffing process
One side done
Leaving my house
One side done
