Re: Old fuel!!!
Siphon it all out, mix it in with your car 1-2 gals at a time.
Here is a post from another forum on the same topic:
"I have encountered a similar situation at work, I have aproximatly 200 gasoline powered boats (not including the 400 deisel powered boats) that I store and maintain. One of the things I havet to do is de-fuel the tanks and fuel bowls and preserve the engines for long term storage.
Waste gasoline is classified by the EPA as a hazardous waste primarily due to flamibility. The "proper" way is to pay a whole lot of money for someone to pick it up and dispose of it, usually by incineratio. By law you have to have special endorsments to transport hazardous waste, (ironically the fresh gas in your gas tank requires no special endorsments). I work for the government and being a steward of the taxpayers dollar I can't see wasting our money like that. We double filter the used gas and add it to our forklifts and small equipment like gensets, air compressors and chain saws. We have even used it in our work vechicles with no problems. We try to use a 3:1 or 4:1 mix of fresh gas with old and add a fuel stabilizer (it's mostly ethanol). Every now and then something might run a little rough and in that case we drain it out and add a little more fresh gas.
So long story short, filter it, drain any water off the bottom and use it in your lawn mower just cut it down with some fresh gas first and add a little fuel stabilizer. DO NOT pour it on the ground!"
