Not sure if i have posted this in the correct area,...
why has no one ever done a hydraulic type drive on a boat?
no big hole on the transom would be needed just a couple hoses,
to a hydraulic motor from a hydraulic pump attached to the engine?
might take some engineering to build some sort of inboard outboard like
leg to hold the hydraulic motor, other than that you think it would be simple.
matt
matt
