Welcome Guest - Sign Up today
No announcement yet.
cutting bimini top and mounting
  • cutting bimini top and mounting
    I am looking at buying a used bimini top for my boat I have found one but it is taller than I really want. I have read were people have cut the main pole at the bottom to lower them. I have not seen it to know how much can be cut so I will ask about how much would I beable to cut on a about 52" top. I am trying to decide how and were to mount it on my boat to work the best. I have seen them mounted all of the boats on the side windows on the outside of the windows or on the inside. Any mount better or worse I would think mounting to the top of the side windows would be the worse on stress.
    1974 Starcraft Holiday 18; merc 115
    2003 Silverado crew cab Dually with Duramax
    1985 Century mirada 255 Sold
    1985 Wellcraft 210 Elite Sold
    1999 K3500 Crew Cab Dually 4x4 7.4 Sold
    Re: cutting bimini top and mounting
    The strongest mounting location would be on a flat surface....preferably on the top of the gunwales.......thru fiberglass.
    If possible, use SS hardware and thru bolt the mounting pads and use nylon lock nuts and a fender style washer.
    • #3
      +1 THat is exactly what I did. My bimini top was way to high so I cut it down and put SS hardware on. Last year when I bought a tower I once again had to cut it down more to tuck it under the tower.
      1994 19' Chaparral 1930SST Bowrider 5.7L 4bbl Rochester
      • #4
        More mounting options:
        • #5
          Also when I was looking at new ones they said they would fit like 80-88 wide how do they adjust for different widths.
          • #6
            The easiet way to cut it down would be to unbolt the support tube from the mounting foot and then cut there and re drill the hole for the sleeve of the mounting foot to slide back in and use the sotck hardware. Remember since its probably stainless its harder than steel and will take longer to cut and drill. When drilling try to step up the drill sizes and use some cutting fluid.
            1997 Crownline 202 BR
            5.7L Merc. w/ Alpha 1 Gen. II
            Sold 1974 15'6" Mark Twain with a '79 115 HP Merc' Tower of Power.
            • #7
              The don't have an adjustment feature for width.
              You just spread the support tubes outward enough to reach the mounting connections.
              • #8
                Okay I figured that was the way the width worked. I figured that was how to cut it for height and I have worked with stainless before. I have plenty of tools to cut it and drill holes with a drill press even. I can even tig weld stainless so changing things is not a big deal.
                • #9
                  When you order them they give 2 inches in or out on each leg thus the 8 inches overall. If yours will fit from 80 to 88 it was ordered as an 84 inch when new. Yours probably has the caps that fit over the ends of the down tubes which is common on the stainless stuff. I have seen them though that the end piece(eye fitting) is held in via a crimp in the tube and unless you have the tool to crimp it not easy to redo. Thats usually more on the alum. tube units though. When I installed mine I went with the fiberglass mount on the outsides of the windshield. I didn't want to mess with the windshield AT ALL one thing goes wrong and you are looking at a very expensive screw up. Plus the flat fiberglass mount seemed much more sturdy to me.
