Welcome Guest - Sign Up today
No announcement yet.
Tow rope gets caught in wake when towing tube
  • Tow rope gets caught in wake when towing tube
    When towing a tube, the tow rope often gets hung in the wake and won't allow the tube to cross over the wake. What may be causing this and can anyone offer suggestions to correct the problem?
    Thanks,
    When towing a tube, the tow rope often gets hung in the wake and won't allow the tube to cross over the wake. Not a problem when towing skier, only when towing a tube. What may be causing this and can anyone offer suggestions to correct the problem?
    Thanks,
    • #3
      Re: Tow rope gets caught in wake when towing tube
      More throttle
      When goals have no clear focus, neither will the actions of the people trying to achieve them
      • #4
        Riding too low most likely. Are you towing with a harness or off the stern hook ?
        sigpicMarada 2100 Executive Series, 5 Litre V8 with Mercruiser Alpha 1 outdrive. 2007 K-Z Spree 260 RBH, all = a whole lot of family fun !!!!
        • #5
          Im towng with a harness attached to the 2 stern hooks. These are the same hooks used for securing to the trailer. Could they be to low?
          • #6
            Do you have a "float" on the rope closer to the boat than to the tube? I do and have never had any problem pulling a tube. And it never gets caught in the wake. Also, maybe your tow ring is too low?? Good luck.
            sigpic
            Brian
            Same Admiral since 1973
            2011 Chaparral 206SSI, 5.0L VP GXI SX, 270HP
            2013 Ford 150 Platinum Super Crew, Eco Boost
            2013 Infiniti G-37
            • #7
              You have at least three choices:
              1) go faster to flatten the wake
              2) raise the attachment point where the tow rope connects to the boat
              3) add a float to the line; there are large oblong floats sold specifically to keep the tow rope above the water. You can buy one on iBoats: http://www.iboats.com/4k-Booster-Bal...view_id.484190
              1992 Four Winns Horizon 200 5.8L OMC Cobra. If you're looking for me on the water, watch for the striped bimini.
              sigpic
              1983 Prindle 16 catamaran
              Old Town Penobscot 16 canoe
              Fanatic F100 Sailboard
              • #8
                How about a booster ball?
                PMs of any type will be promptly answered.
                2006 Tahoe Q4 Sport,
                19.6', 4.3L V6 Mercrusier I/O, Red
                No live wells, fish finders or rod holders.
                sigpic
                • #9
                  Please do not post the same question in multple sections. I am merging the threads.
                  2002 20' Hydra-Sports 202DC 200HP Yamaha HPDI
                  1976 18' Starcraft SuperSport 90HP Evinrude
                  Restoration thread https://forums.iboats.com/showthread.php?t=357767
                  • #10
                    Am not sure how fast you are going but more speed sometimes is not the answer. When I have the grandkids in the tube and want to get them outside of the wake all I do is first turn fairly hard one direction, when the tube starts changing directions I turn fairly hard the other direction. With a little practice you will be able to get the tube on the outside of the wake.
                    sigpic "Spend a little money, save a lot of time"
                    • #11
                      trim the bow down
                      A man of constant boat tinkering.
                      • #12
                        I will go with the liklihood that the u-bolts he is using are probably too low to allow sufficient height above the water for the rope. The skier success is due to the taller skier creating an andle which is enough to keep it out of the water. The rope-rulley he is likely using between the tow hooks, is exasterbating the problem. The booster ball is about the only thing that will help if he doesn't want to create a new mounting point or raise his tow eyes.
                        What type of boat is this?
                        1976 Mark Twain 200VBR w/Mercruiser 233 (Ford 351w) "Heart & Soul"
                        • #13
                          Regardless of the type of boat, the height of the stern eyes will vary very little, maybe a few inches and that won't make much difference in keeping the rope out of the water. The rope floats help a little.
                          Since ski pylons are not recommended for pulling tubes, the most effective solution is driver education and experience. As boat1010 pointed out, the technique is the key.
                          I've successively pulled tubes in a 14ft whaler style hull where the stern eyes are only about 6" above the water.
                          • #14
                            I have pulled tubes where the stern eyes are right above water level (Quantum bass boat), it really depends on the boat he's using before we can speculate that he is trimmed too far up or not moving fast enough. Some boat hulls produce a natural center wake that can catch the rope-pulley, and the only way to reduce it is to go faster, which with small kids won't be an option, and it may be too fast for anyone to be pulled safely.
                            • #15
                              You guys are way over-engineering this thing. It's a simple matter of shortening the rope ...
