smitty2640
- Apr 7, 2009
- 3
I have an 18 ft. (2004) Polarcraft Duck boat with a live well.
The person I bought it from made some alterations to the pump system in the actual live well tank. I think to make room for storage!
It appears that they sawed off several of the pipes that feed and dump water from the well.
1. Can anyone tell me how the drain plug in the bottom is supposed to look (right now it has a rubber cork). I am aware of other systems. There are three holes. One in bottom that looks as though it was sawed flush.
2. The hole in the side of the boat that appears to be an overflow. It is a straight hole with no screen, etc..
3. Then there is the feed hole which now dumps water into the well with no pipe to distribute the water evenly.
4. And the pump itself is an in-line cannister type (looks like a small keg). Can that be serviced? Or anything I should do to it? It works but pressure is low.
5. Also, can I buy the required pipes if need be. There are threaded fittings on all three. And where can I buy them?
ANY HELP WOULD BE APPREC.
THANKS IN ADVANCE.
SMITTY
THANKS IN ADVANCE.
SMITTY
