best aluminum boat?
900cfi
I know I will get alot of opinions but who makes the best deep v alumin7um fishing boats?
Re: best aluminum boat?
Are you trying to start a fight??? Lund, Crestliner, Alumacraft, and about a dozen other manufacturers. Depends on what you want, how you fish, where you fish, what you fish for, how many people you fish with, how fast you want to get to the places you normally fish at, and how much money you have to spend.
900cfi
Not trying to start a fight,just a simple question for those who want to give their own opinion.I'm looking for a 19-21 deep v boat for fishing lake trout and walleye that can handle big water.Also want a boat that gets on plane and gets a good speed for the recommended hp.
CATransplant
I take it you're somewhere in the upper Midwest, then. I think that, if you stick to the major brands, Lund, Crestliner, etc., it'll be hard to go wrong. They each have their followers and perform well.
I think what I'd do is start visiting dealers (assuming you're buying new). Somewhere, a dealer has a leftover model from last year, an order that the buyer backed out of, or something else that will make a boat a great deal for you.
Don't be afraid to range out from your home town...I'd drive several hundred miles to save $1000. Somewhere, there's a boat with your name on it. And, as the season goes on, the prices go down, too.
KCook
"handle big water. Also want a boat that gets on plane and gets a good speed for the recommended hp"
Unfortunately these are conflicting requirements. As for boat brands, I'd include Alumacraft, Crestliner, G3, Lowe, Lund, Polar Kraft, Princecraft, and Smoker Craft. Which is a bunch, I know. Motor brand choices with your local dealers may well narrow this down though. May as well stick with the motor(s) you like.
Kelly
900cfi
Kelly
Thanks for the reply.I was looking at those boats and I want a 175 e-tec or 175 optimax for an engine.I sorta thought that all of those boats you mentioned are all very good quality.
Add Sylvan and MirroCraft to the list. The majors (Lund, Crestliner, Alumacraft) will have the best resale down the road.
Skinnywater
If your asking for the "best" those other brands are in a different class altogether.
Mine has 10 inch aluminum box beams under the decking that run both sides longitudally and tied together with 3in. square aluminum tubing transversally.
All seams and joints are continuous welds on both sides. This constitutes a "rockhopper" hull. This is done even in places that aren't seen with the prettyest welds you can imagine.
The aluminum hull and decking material is a bit thicker also.
http://www.northriverboats.com/
900cfi
Are the targa's built by Tracker a good boat?I looked at their website and they look like a nice boat.
KCook
Optimax should be very easy to find, since so many aluminum builders are now under the Brunswick tent. E-TEC may be more of a challenge, depends on your dealers.
I wish my Tracker had been a Targa model. The Targa models really do look nice. May be as well built as some of the others. But the Tracker name just won't get many shoppers excited, come resell time.
If this is to be a new purchase, not used, then picking out the dealers you like will certainly shorten this list.
Kelly
redtech
i would go to heavy gauge take a look at the north river, resale is good and you get a chance to customize to your taste
ezmobee
Just catalog shopping and I was impressed with the features that Starcraft and Sylvan aluminums had,
rndn
Just remember that you get what you pay for. If it's substantially cheaper then there are reasons for it.
evilratgirl
I've got an old 18' Crestliner and love it. My father in law has an older 18' Lund Tyee. With aluminum boats the term big and fast really isn't as much of a conradiction as it may seem.
I always thought that if I had the cash, the Lund Baron would be cool. Big deep V ment for big water with cush.
Booner
That’s a loaded question sure to start some debates. All aluminum boats are made very well. Lund has a very large following with the walleye guys and probably has the best resell value. It seems that all others try to compare to Lund. But I’m bias I own an 18’ Lund Fisherman.
900cfi
I went and looked at a Tracker Tundra and wow what a beautiful boat.The only thing I don't know if I like is that they only come with a mercury.Anybody seen a Tundra with a different outboard other than a merc and does anyone have any experience with this boat?
dabalone
I will chime in on Tracker since you are interested in them. First you probably will not get much support in the forums for tracker boats, but I bought a new one recently. Its a pro guide 17 with a 115 optimax. I also looked at the Targa but liked the lower sides of the pro guide for less money, other than that they are very similar with the Targa being little wider, deeper and steeper deadrise. I also looked at some other brands and compared before buying.
I got the boat to get my sons and I out fishing. It will see multi uses also, lakes, river, delta with a little tube pulling now and then for the kids. So far I really like the boat, it is roomy for its length, and rides very good in choppy water. But I have had problems with a crappy steering system, tracker has replaced that already but with just another crappy steering system. Seems to be a couple very tight turns the cable makes getting back to the motor, they are now offering to replace it with Hydraulic steering. Another problem is porpoising at just around 4600 rpm and I have to throttle back at 5200 rpm because it gets a little scary. This leaves me without the performance the motor is capable of since its rated at 5750. As I speak Tracker is also working on a solution to the porpoising problem. I think it is overweighted at stern and light in the front, we will see. The boat wants to hug the left side of trailer when being pulled out of water and ride up on a fender well some, Tracker has authorized a custom trailer busness here to add side bunkers and correct that minor but irritating problem. Tracker so far is acknowledging and taking care of any problems.
To get a second opinion on the porpoising problem I have talked to another marine repair and setup busness. This place was recommended to me since they set up new boats with motors, jackplates etc., and also do the welding for repairs on alum boats. Including all the top brand names in alum boats.... you know the ones that cost about as much as a small house. I am taking my boat to their shop for an anaylisis of what is causing the porpoising and stiff steering and what they may recommend to fix it. In our conversation today he told me he has worked on the new tracker boats and the all welded hulls are solid with good welding. Again you probably will not get much support for Tracker boats, I believe they may desserve some of the hard knocks from the past but feel I got a very good bang for my buck compared to some of the other alum brands out there ... which can cost enormous amounts of money.
