Transom height terms
EHardgrave
What do LS and SS mean for a transom height. I am seeing this on Smokeercraft's Alaskan model.<br />Thanks
Dhadley
Re: Transom height terms
LS is long shaft or 20" models (top of transom to keel).<br /><br />SS is short shaft or 15" models.<br /><br />XL is extra- long or 25" and XXL is 30".
EHardgrave
Thanks for the info.<br />How could a boat be able to use both?
Dhadley
Not sure what you mean. The transom height is either 15" or 20" or 25" or 30". Its usually not easily changed.<br /><br />What is it that they say?
EHardgrave
Length 11'10" <br />Beam 63" <br />Depth 24" <br />Interior Depth 19" <br />Transom Width 56" <br />Transom Height LS/SS <br />Dry Weight lbs. 185 <br />Max Persons 3 <br />Max Capacity lbs. 700 <br />Max HP 15 <br />Fuel Capacity gal. N/A <br />Bottom Gauge 0.064 <br />Side Gauge 0.060 <br />Rib Gauge 0.064 <br /><br /> http://www.smokercraft.com/utilities/alaskandeluxe12tllxs.htm
JB
One example is the Boston Whaler Outrage-18 of the 80s.<br /><br />Single engine. . . 25" or extra long shaft.<br /><br />Twins. . . 20" (long) shaft engines.<br /><br />5" of deadrise between center of transom and the outer portions where twins would mount.
surlyjoe
A 56" wide transom would suggest twin motor capability. sounds like JB knows the score
Dhadley
Now years ago it seems there were some boats around with 18" transoms. Maybe thats what they mean. It'd be worth a call to see....
rickdb1boat
You might be right, Dhadley. Noticed that the "Interior" depth is 19"....
EHardgrave
Thanks for all the info. I will call a SC dealer south of me and see what they say. I just can't imagine two motors on a 12' boat with a 15hp max. Maybe you could order either way. I will find out.<br />Thanks again for the info.
rickyp52
What they mean is you can get it with a 15" transom or a 20" transom. The choice is yours. Twins on a 12 ft boat? I think not.
