Welcome Guest - Sign Up today
No announcement yet.
Do Key Largo Boats Have Closed Cell Flotation in the stringers?
  • Do Key Largo Boats Have Closed Cell Flotation in the stringers?
    Looking at Key Largo Boats 1720 CC, does it have closed cell flotation in the stringer system?
    Bring rain gear !
    What year?
    Experience is a lifetime of mistakes, wisdom is not making them again.
    • #3
      OOPS , I meant Key West 1720cc - a new one
      Bring rain gear !
      • #4
        if it has engineered stringers, then most likely yes. most engineered stringers use foam in various places.
        however as all expanding foam in boats starts out as closed cell foam.
        then over the years the foam may break down as exposed to water.
        call Key West and ask.
        Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
        1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
        Past Boats
        1970 Wooster Hellion - Merc 9.8
        2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
        1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
        What’s behind you doesn’t matter.Enzo Ferrari
        • #5
          My current boat, bought last summer is a 2002 model, closed cell poured in foam, and I was suspicious of the foam due to the surface discoloration with petroleum products and bilge water. So I cut a chunk of it and put it in a pail of water. It floated like a fall leaf on a brook. So much for worrying about the foam.
          If you are new to boating or have a new boat, a knowledgeable friend could show you how to operate your boat and save you a lot of grief, maybe some money, and maybe your life.
