I’m not exactly sure where to post this but here goes:
I picked up a project boat - Lowe 16/48 bare hull. Someone had previously removed the middle bench so it’s a bare bull, pretty light weight. I put a 1993 Mercury 40 hp short shaft tiller on it. I took it for test ride today and have some issues. The motor runs good alright, too good. I can only run about half throttle. Anything past that, the boat seems to lose contact and start to dart sideways and dig. Not motor cavitation but simply the boat gets out of control. I’ve had multiple 16/48 hulls in the past with 40hp tillers and none acted this way. I don’t think it’s necessarily a prop issue (running a 16p stainless). I also tried running at different trim levels with no noticeable difference. The motor is mounted correctly. I believe anyway. Cavitation plate is even with bottom of hull.
Any recommendations would be greatly appreciated. Maybe need less prop? Maybe more weight? Maybe motor is just too much for the boat?
Been lurking here for quite awhile. Nice resource.
