Welcome Guest - Sign Up today
No announcement yet.
Looking for Alternative to expensive Shrink-wrap torch/gun
  • Looking for Alternative to expensive Shrink-wrap torch/gun
    Anyone ever used anything other than a $500-1000 shrink-wrap gun to shrink ?? Bought some shrink-wrap on clearance but Im not looking to spend big bucks on a gun.Was told the cheapie torch sold at Harbor freight worked well but it was from an unreliable source.Anyone??
    https://www.ebay.com/itm/SHRINKIT-RI...8AAOSwiS9d3xJr
    here you go, $750 gun for $220
    Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
    1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
    Past Boats
    1970 Wooster Hellion - Merc 9.8
    2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
    1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
    What’s behind you doesn’t matter.Enzo Ferrari
    • #3
      You can use a hair drier but it would be slow...
      We shrink 10 mil Poly sheeting for ocean shipments using yur typical heat gun used in electronic assembly, i.e. heat shrink tubing
      Any of these would work
      https://www.homedepot.com/b/Paint-Pa...s/N-5yc1vZc2fe
      • #4
        The heat gun wont work when wrapping a boat or it just wont work the boat cover type of shrink-wrap.I tried a while back to just tighten up a small section with no luch at all.Needs a torch to do it right.
        • #5
          Then use one of these
          https://www.harborfreight.com/propan...ter-91037.html
          • #6
            Yep dingbat,thats the cheapie I was referencing. Just dont know if thats gonna shrink or burn up my boat
            • #7
              When messing with a flame like you're going to need to shrink as much film as you're talking about to do a boat, I would say your boat is going to be at risk. That said, I used a Harbor Freight torch to do my first one this season after having watched it done a couple times by guys that were pretty good at it. They burned holes/overheated the film just like I did! Job went well for the most part. My best advice would be to not try doing it in anything but near calm conditions. Wind makes things too unpredictable, will test your patience, and that's when you overheat the material.....
              • #8
                Thats the gun I was referring to,so if you say it works.....for $35 I will give it a shot
                • #9
                  I would suggest you practice.
                  Try it on a couple of old bikes, a wagon, or a couple metal garbage cans.
                  Do NOT try wrapping the wooden picnic table, or the wife car.
                  Medford, WI
