Welcome Guest - Sign Up today
No announcement yet.
Alpha One Drives
  • Alpha One Drives
    i want to use an Alpha One gen 1 on a gen 2 setup. I know you can't use a gen 2 on one with a gen 1 setup but what about putting the gen 1 on?
    look in the stickies. the difference is explained there
    https://forums.iboats.com/forum/engi...4-3-block-swap
    1990-4-3-century-2000-floor-transom-stringer-upholstery-project
    • #3
      In a word no won't work. Among other things Shift mechanism is different
      • #4
        Swap the transom assembly and it will work. Just involves pulling the engine forward..
        If your doing it for a cheap drive, SEI drives are only $1,500 new
        1961 Custom Craft Sea Ray- 1964 Mercury 650. In family since new.
        • #5
          Ayuh,.... Welcome Aboard,.... Nope, they won't interchange, either way,.....
