Gee, those pictures did not indicate where the cracks were located. usually stress cracks are located on areas of the most stress...like transom corners, and where the hull meets the transom. where are your's located?
I do not see any fiberglass cloth exposed, which is good. You can get cracks like you have from hitting something, with your pattern looking like it hit a piling.
You might push on the hull where the cracks are and see if she gives. The hull can detach from the top cap of the boat, and the sides can be pretty weak because of it. The fix is to bolt the cap to the hull sides with SS bolts and locknuts.
