1993 Stratos 201 Pro XL manual or diagrams needed.
slayer021175666
Hi Guys.
I'm trying to find an owner's manual or any wiring and cable or tube routing info I can get for the 1993 model.
If you guys can help me out, I'd really appreciate it!
Thanks in advance.
jbcurt00
Wiring diagrams/routes likely never exist
owners manual was probably extremely basic and of no real help w wiring/routing either
Silvertip
If you look thoroughly you should be able to "see" the cable conduits. Use a plumbers snake to pull through whatever it is you need to pull through. At the same time, pull a cord through and leave it in there should you need to pull something through in the future. Boat wiring is very generic. There are many diagrams in these forums.
