Hydrofoil On A Suzuki
TinyKnott
2013 Blue Wave 180 super tunnel pro w 115 Suzuki & bad cavitation , I have ordered SE-Sport 300 High-performance turbo Hydrofoil , I hope it helps any ideas ?
GA_Boater
TinyKnott Welcome aboard.
Moved this out of a old thread to a thread of your own for better results.
Not familiar with your tunnel hull, but often cavitation is the result of poor set-up. Motor too high or motor too low for example.
Can you get some photos of the motor in relation to the hull, from the side is best?
82rude
I would go with the above posters suggestions and before I added a foil I would consider smart tabs which are much better suited for your issue and much less snake oily than those foils,but seeing as how you already ordered it good luck ,you might get very lucky .Ive had both and the only one that worked for me and instantly was the smart tabs .
ahicks
Those foils (whale tails) are real good at cracking/breaking the plate they're attached to.
H20Rat
Also, you most likely have ventilation, not cavitation. Vastly different problems and solutions. As GA said, pics...
