porchlight
- Jul 21, 2018
- 47
Hi all,
I have a pretty dumb question about storing a 14' sears/montgomery ward seaking aluminum boat upright against the side of my house.
I've seen people just tip them up and lean them up against a house or shed or whatever, and I finally tried it for the first time myself yesterday. In my head, the transom was flat, and it would just sit on the transom and be fine.
In reality, however, the transom isn't flat—there's an angle to it. The result is that when the boat is straight up and down, the stern/transom is resting on the very "top" of the transom instead of the whole transom.
Hard to explain verbally.... but if you take a boat like this:
and tip it upright agains the wall.... the transom isn't sitting flat on the ground. The Top of the transom, where the motor mounts, is the only place touching the ground, while the "bottom" of the transom, where the drain plug is, is in the air, like so:
So what I'm wondering is: For a 14" aluminum boat, that's incredibly light... is this a problem? Will the weight of the boat cause big issues or anything?
If not, then great! I'll just keep it as-is.
But if this will cause problems: What can I do about it? I thought about just building a little platform at the correct angle to fully support the transom, something like this:
or I'd also really appreciate any other suggestions that anyone has!
Thanks!
p.s. holy cow, I'm sorry for the drawing quality
Thanks!
