Hello All
I have 1998 Four Winns Vista 258. I recently replaced the bilge pump in the compartment just in front of the aft cabin. The one I put in, Atwood, I know it is used to pump out water from the shower drain etc.. My question is , there is a forward bilge pump switch on the cabin wall. I turn it on and there is no results. I have read that the forward bilge may have been an option on this boat. Is that correct? Or am I missing something. I have attached the picture of the compartment (trying to upload). If anyone can explain what the white pump in the glass case is and what it does and where if any is the forward bilge.
Just a note the area where the pump is , is bone dry.
Finally the new bilge pump I installed for shower water is not powering up. I think it may be the fuse, I also read the fuse is in the engine compartment with the rear bilge. Again any help would be great locating the fuse and explain the above bilge questions.
Todd
Todd
