further
- Jun 18, 2009
- 1,031
Hey all, 2004 Sunesta 234 - I've been noticing a really nasty sewer smell at the stern of the boat - while anchored and swimming after the head has been used quite a bit. It doesn't smell in the head compartment itself - only at the stern and in the cabinet beneath the sink which is adjacent to the head compartment - assuming the waste line runs under this.
This is my first boat with a head - there is one sea **** in the bilge which i assume is the inlet for the fresh water - hoping there isn't another that I don't know about that is letting the waste overboard and that's what i'm smelling.
The waste tank appears to be solid - no leaks and the hose clamps are tight and in good shape. I replaced the joker valve and seals in July because the head wasn't holding water. Anyone with the same setup that can shed light or tell me where there would be another sea **** that I'm not seeing?
Thanks in advance.
Thanks in advance.
