jasonbradmorris
- Jun 28, 2003
- 18
I have a 06 Tracker Pro Team 175tw. This past weekend, I ran into a couple of issues that I can't seem to find the answer for. One is mechanical and the other is electrical.
First, my 60hp EFI Mercury was running like a top at the beginning of this season. I ran it last weekend and it was still going strong. I fished a tournament on Saturday 8-18-18, and noticed that the motor did not have water pumping through it and the RPMs were idling at 3000+. I saw that my port was clogged on the motor. I clear the debris from the port, and got water to start pumping out, but it seemed to be at higher pressure than normal. I figured that it was from the higher RPMs. What could be causing the high RPMs to show up 6 days after running perfect?
Second, I had a livewell full of fish with my automatic recirc pump turned on. I also had my graph turned on as well. As I was trolling along, EVERYTHING electrical shut off and will not turn back on. I removed the fuse panel under my console and checked every single fuse and did not have any that needed to be replaced. I have had the problem with the recirc pump blowing a fuse before, but it has never shut everything down. The trolling motor still worked, but nothing else would turn on. There was no livewell pump, recirculation pump, bilge pump, or aerator. It was fine one second and gone the next. I can't place where to even start looking to solve this problem.
If there is any help that can be thrown my way, I would be greatly appreciated. I am not a mechanic, and electrical is harder to find than plumbing. At least with plumbing, you can see where the problem is.
