Hello,
I am currently wiring my center console, with a bilge pump, and navigation lights. Do you think I should wire the bilge pump and navigation lights to the ignition, or to the battery? I believe the ignition system uses 14 gauge wire. Will I be drawing too many amps through the ignition system? I will utilize fuses for either approach. I would prefer to run through the ignition system to avoid a dead battery, as I only have one for this setup.
Thank you!
Thank you!
