- Mar 8, 2009
- 40,714
Yesterday was working on the boat getting ready to put it in. Removed a rag placed in the bilge and found a freeze plug laying in the bilge.
Started to sweat and put my head further down and noticed the block plug on the port side was still in. Also notice a rusty hole where the plug came out, the middle plug was half out, and felt behind the motor mount and found that one still in place.
Picked up a light and looked over the side of the block closely, and did not see any cracks. Cleaned the hole up with sand paper, used some high tac sealant and re-installed plugs.
Fired it up, no leaks and no extra oil. Dunked it in the water and brought it around into its slip. Still no leaks and no extra oil. Man did I get lucky AGAIN
This happened about 15 years ago with my Rinker. That time it was the starboard side. Said then as this time. I will not do this again, but it happened again.
Remember looking at all the plugs and thinking there should be one more, but had someone talking to me so I got side tracked. Hope I remember this time better.
Don't think SBC would be able to take the same freeze issue, but don't want to test the theory
