What is the best spincast reel under $50 ?
colding01
Re: What is the best spincast reel under $50 ?
Forget those two... The single best spincast reel ever made is the Zebco Omega. They come in 2 sizes, one spooled with 4 lb. test and a larger one spooled with 10 lb. They are the smoothest, most durable spincasts I have ever used and cast better than all the others I have used, and I have used a lot in my lifetime.
Sevcrist
I'll second the Zebco Omega. I bought one for my mother and the quality etc. of the reel is far better than any other spincast reel out there.
monoshock
Thanks for the input.I’ve used a lot of Zebco 33’s in the past, haven’t used the Omega yet.
JB
When I used spincast I had my best performance from Zebco 33s and Zebco One. Haven't used an Omega, but I trust Zebco.
monoshock
Thanks for the link, Sevcrist :) <br /><br />"The Zebco Omega is the only spincast reel to feature 6 stainless steel ball bearings".<br /><br />Sounds good to me. :)
llfish
No question the omega is the best real for the money and better than my $200 reel.
rayjay
That Omega sounds good. I have several of the Daiwa Goldcast III's. They make a GC80, GC100, GC120. Intended for 8, 10, & 12 lb line respectively. Oscilating spool, rotating sleeve on the pick up pin. Pretty good drag system. Definitely don't have 6 brgs :p One of the best Spincast reels going for sure. The only real negative is the ratchet pawl anti-reverse. Click click click click ................
monoshock
Thanks everyone for your input :) . I think the Zebco Omega is the one I’ll buy.<br />Any suggestions on where’s the cheapest place to buy one? :rolleyes: <br />Looks like around $49. is the going price.
colding01
Yea, BassPro has it for $50. I got the smaller one. It comes with an extra spool that I keep 4 lb. on for crappie fishing. I took the 6 lb. off that came with the reel (it seemed a little weak), and spooled it up with some Trilene Xtra Tough 6 lb. test. Works wonderfully! I've had it for about 6 months and some lots of heavy fishing done on it. I haven't had to clean it yet!
rayjay
Tonight I bought one of the smaller Omega's. Looks pretty good. I put it on a light action rod to use trolling for trout on the hooch. We use ultra lights for casting for trout. <br /><br />Pretty funny, $50 reel on a $12 crappie rod :D
JAG59
Spincast? Aren't they all under $50?
colding01
Yea, they are all pretty much under $50. Most are under $30 including a rod.
