jparm13, If you've never used a bait cast reel before, I'd suggest buying one or more used ones off EBay first. WHY? Because they are very cheap and then you can try a few without a lot of funds expended and learn what you like and what works the best for you. I will say, they don't cast like any other type reel. You literally have to learn how to cast them. But once you do, you will love them and their capabilities.
The first thing you have to do is set up the reel. And that is true for any type bait casting reel. You have to use the proper weight lure as well. Some reels will cast lighter lures while others have to use heavier weighted lures.So select the proper line and lure that works for your reel. Next you click the release and allow the lure to drop to the ground while holding the rod horizontal to the ground. Once the lure hits the ground the reel should stop spinning as well. If it continues, there is too little load for that reel. So you tighten the reel until it stops spinning when the lure hits the ground. Now you adjusted that reel for that weight lure. Then you cast releasing at a different point then other closed faced reels. That will have to be trial and error on your part. Experiment with your release point until you see how that works. You back swing to load the rod and then use the release point from your experience. It takes a little time, but once you sort of master that technique, you will be amazed at the accurate and distance you can cast.
Check EBay for such reels and buy a few cheaply first. I have bought a lot of them and not one was a disappointment for me. JMHO
