Eduardojuan
- May 20, 2015
- 1
Same issue with a Yamaha 30 ELG. Had the engine in reverse in order to access linkage nuts. Moved the shift lever up between neutral and reverse after shift linkage coupling was loose. With lower unit out, I placed the shift lever in full reverse and pushed the shift linkage all the way down in order to place lower gears in reverse. Something went wrong. After replacing the impeller, I reassembled the lower unit to the engine, prop turns forward (clockwise in my engine) while the shift lever is in neutral. I have no neutral. Need some ideas please.
