2001 DF70 Trim/tilt not working
Inspector64
I have a 2001 DF 70, I just replaced the Trim/tilt motor which failed last fall when I winterized it. The motor is working but there is no back pressure either up or down, Hydraulic fluid is full and not contaminated. I am thinking that one of the check valves inside the pump mechanism may have failed. There is no pressure being generated in either direction. Any help would be appreciated.
Lance
