I have a 1998 Suzuki DF70 that is leaking oil from the water intake ports at the bottom of the engine. When the engine is running there is a large oil slick around the motor at idle. After a 30 mile run the oil light came on. I measured the oil level in the motor and it was below the lower level of the dipstick. I figure I am losing about 1 quart of oil an hour from the leak.
I have pulled all of the cowlings and lower foot off the motor in hopes of finding the leak but nothing obvious was found. I drained the oil and could not find any indication of water in the oil but I did find chocolate milk in my water cooling shroud where the pee hole is connected.
I also pulled all of the plugs in efforts to locate a ring or head gasket issue but the plugs lock good. I have attached pictures of the plugs for reference.
At this point I assume that it is an internal gasket? Any help would be appreciated.
Thanks!
Thanks!
