Removing Lower Unit From Suzuki 1980 DT25
dgw_181
I'm hoping someone can help me.
I need to remove the lower unit from my 1980 DT25. to service the impeller and cooling system.
I have removed the 4 bolts and uncoupled the shifting rod about half way down the leg under a small cover. Even though I have done this the unit still will not drop I can only get it to move about 5mm.
Is there something I'm missing???? Please help.
Re: Removing Lower Unit From Suzuki 1980 DT25
On my dt65 there was a big bolt going up from under the cavitation plate as well. Try there. I don't know if it is the same on yours but worth a look.
