Welcome Guest - Sign Up today
No announcement yet.
suzuki dt55 lower unit
  • suzuki dt55 lower unit
    [I] have a 1985 Suzuki dt55, Im trying to remove the lower unit, I also have a 1994 dt75 but they seem to use a different setup to conect the shift linkage on this dt55. any help would be wonderfull this manual could not be more non specific
    thankyou
    Re: suzuki dt55 lower unit
    Look under your bottom carb with a flashlight, follow your shift linkage and find a large chrome nut. Loosen it only about three turns while pushing the shaft over until the pin slides out of the shift rod. Make sure the shift rod doesn't hang up on anything as you lower the gearcase.
    • #3
      I got it mphelle Im going to get the water pump put in and hopefully put it back on tomorrow thanks for your help
